My parking lights wont turn off!!!
Old Jun 28, 2002 | 07:45 PM
Don_89Iroc's Avatar
ever since i had the new motor put in my car as soon as i turn the key on my car the parking lights come on even if the switch isent on and they stay on until the car is off and the key is off, why would it do this Please help! Thanks -Don
Old Jun 29, 2002 | 05:31 PM
dale davidson's Avatar
headlight switch or relay(s)? or a ground to low i think itwas called in tech school.
Old Jul 1, 2002 | 12:42 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Sounds a little like the brown wire that powers all the front & back marker lights got hooked up to a +12v ignition-on wire under the hood somehow. There is a brown wire on the (looking from the front) left of the bulkhead connector (parking lights & unfortunatly, a brown wire on the right side, I can't say what this goes to but, it's hooked into the alternator on the 88 tpi harness I'm putting on my friends 72 truck. I've found no diagram showing what this wire is (even a 91 firebird manual at a dealership), but, I guess this is the +12v signal from the regulator to the voltage gauge, I haven't quite got that far splicing wires just yet...
Old Jul 1, 2002 | 11:20 AM
2vmodular's Avatar
if the car ever had an aftermarket alarm system installed, double check any connections into the vehicles harness. some installers have been known to twist the wires together without using any solder. scotchlocks and other crimp on connectors can cause problems too.
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
