electronic hatch release doesn't work on Firebird
Old Mar 2, 2001 | 10:17 AM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
I have a 1988 GTA with a digital dash and the electronic hatch release button mounted on the dash. I have replaced the switch and it still doesn't work. I have a button on my Clifford alarm remote that pops it and it works. So I know that the thing works. What could be wrong? This started to happen when my emergency brake light indicator on the dash went out. Does this have something to do with it? I don't want to have to replace the brake light bulb behind gthe dash because it's a PITA. I had to do this before when the Service Engine Soon light burnt out. The only way I could open the hatch is throught the remote and the key.
1988 GTA 5.7L TPI Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Balanced Bosch 22 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 4 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Flow Tech Pre-Cat 3" Exhaust Cut Off, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials 255/50 R16, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 2, 2001 | 01:21 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The hatch switch operates a relay that is grounded through the PRNDL switch and the starter solenoid, when the PRNDL switch is in P or N. This prevents the hatch from being opened when the PRNDL switch is in R,D,2, or 1. Check the operation of the relay - it is located in the center console in Camaros - I'm not sure if it's in the same location in a GTA. If a starter disable relay was recently installed, this may be breaking the grounding path for the hatch relay coil. If that is the case, move the starter disable relay upstream of where the hatch relay coil taps into the wire going to the PRNDL switch - place it between the ignition start switch and the hatch coil / PRNDL switch.
Tim
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Wade787b
Sep 29, 2015 01:15 PM
