Wiring a 3 Wire O2 Sensor
Old Mar 4, 2001 | 05:58 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
I just bought a 3 Wire Bosch O2 sensor for a ZR1 Vette part number 13077. How do you wire this thing up to a one wire O2 sensor for a 1988 Trans Am GTA 5.7L L98 one ire O2 sensor?
1988 GTA 5.7L TPI Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Balanced Bosch 22 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 4 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Flow Tech Pre-Cat 3" Exhaust Cut Off, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials 255/50 R16, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 4, 2001 | 06:38 PM
Blade's Avatar
Simple... you hook up the black wire from the sensor to the existing 02 wire from the car, and the other two wires... one goes to ground and the other to ignition switched 12 volt power.
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
Ironhead38
Sep 7, 2015 02:26 PM
