HD Blinker Unit
Old Mar 7, 2001 | 03:29 PM
AmorgetRS's Avatar
HD Blinker Unit
Does anyone know of a heavy duty blinker unit for a 1990 Firebird. I went to a Trans Am style tail light and now the blinkers are kinda messed.
Also, pertaining to this, anyone know where to get a heavy duty relay for the entire tail light system? Brakes, blinkers, and normal tail lights?
Thanks a ton!
Douglas
Old Mar 7, 2001 | 04:53 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If the turn signal flash rate is now different & you want to return it to the original flash rate, install an electronic flasher, or a non current sensing type flasher (like is used for the hazzard flashers) in place if the original current sensing turn signal flasher unit.
Tim
Old Mar 7, 2001 | 07:52 PM
AmorgetRS's Avatar
Okay, cool... now I feel really dumb, but where is the Flasher unit located at? Also, is the "non-sencing" unit a direct replacement for the normal flasher unit?
Thanks,
Douglas
Old Mar 8, 2001 | 02:45 PM
The turn signal flasher is clipped under the driver's side dash & has one purple and one blue wire going to it. The non-current sensing flashing units are a direct replacement, however, they will continue to flash the circuit, even if a bulb burns out.
Tim
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
