Cruise Control Keeps Accelerating Forever
Old Mar 8, 2001 | 09:30 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I have a '92 Z28 with mods below. When I turn the cruise control on, it will increase the speed when the car slows below where I set it, but it keeps increasing the speed indefinately. It does not stop when it gets to the correct speed. All of the other functions work properly. Is this a cruise control module problem, or is it mechanical?
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Double-Pump This! EFI Rules!
Definition:
NOPI: n. 1. import 2. Sticker worth 47 hp 3. import with 6" exhaust tip
antonym: smallblock
Old Mar 9, 2001 | 07:47 AM
Omar's Avatar
If everything else works fine, then it does sounds like the Cruise Control Module itself.
1989 IROC-Z 5.7L
Hotrodboba400
Dec 10, 2019 07:07 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
amcnellis
Sep 16, 2015 04:16 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
