Car won't crank! Q:Would anything blow or short because of starting car without ESC?
Old Mar 12, 2001 | 07:30 AM
F-Messenger's Avatar
I have an '87 GTA 350 TPI. I disconnected the Electronic Spark Control Module (Don't ask me why, crazy idea) and when I turned the key it had a split-second of cranking and turning over then went dead - no noise, but still had full power to everything. I have full power to all accessories, hatch, gauges, radio. I hear the fuel pump click on when the ignition switch is turned to on-start but other that that nothing, no sound or activity. I am showing good voltage at battery and on gauge. Now I'm stuck in driveway since car wont crank. I have had some insights based on another post I have but I am posting this since it is more specific; perhaps new thoughts? Please help if you can. Thanks!
F-Messenger
Old Mar 12, 2001 | 05:07 PM
Update:
I tested all my fusable links to make sure they had voltage on both side of link for each one. I then investigated the purple wire going to the starter. I noted it had "0" voltage and imagined that the when you turn the key it drops 12 volts on it to start starter. So I tested my theory by tapping into the purple wire and then touching it to the 12-volt post of battery (with the key turned to on of course) and BOOM it cranked over without a hitch! So now I must investigate why when I turn the key it doesnt drop 12 volts onto the purple wire. Any ideas? Thanks!
F-Messenger
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
ZsTransAm
Aug 11, 2015 07:30 PM
