Tach problems
Old Mar 11, 2001 | 12:01 PM
leatherneckm's Avatar
Tach problems
Ok, after installing a complete MSD system my tachometer is acting funky. I read through the MSD literature, it says there is an inline filter that must be removed for the tach to function properly. Anyone know what it is, where it is, what it looks like? Thanks.
Old Mar 12, 2001 | 02:00 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Not all third gens have a tach filter, but if you do have one, it will be mounted to the fire wall, behind the distributor. It is a appprox 1/2" diameter x 1.5" long cylinder with two wires attached to it. Disconnect the tach input (white wire that goes up into the harness next to the large pink (ignition power) wire) from the distributor module & connect the tach output of the MSD box directly to it.
Tim
Old Mar 12, 2001 | 02:14 PM
theformula's Avatar
I wonder if this is my problem. My MSD equip is making my tach do the same thing
Old Mar 12, 2001 | 03:48 PM
theformula's Avatar
Hey TIM, do i need to purchase anything else from MSD to do this?
Old Mar 13, 2001 | 02:03 PM
I believe MSD sells a tach filter, but I've never had to use one when driving the factory tach on an '84 & a '92 with the tach output from a 6AL (spade terminal on the side of the box).
Tim
Old Mar 30, 2003 | 07:30 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I am running a MSD universal boost timing master on a stock HEI system and the tach jumps all over at idle.
With the Jacob's system on line the tach is fine.
Why is the BTM doing this on the stock system?
Do I need the MSD filter?
Thanks.
Old Apr 14, 2003 | 11:34 PM
jloshotz's Avatar
Car: 1991 Z/28
Engine: 5.7 TPI
My Tach Is Funked up too. All I have Is an Accel Super Coil which was installed when my new engine was dropped in an the tach hasn't worked right since. Is this filter in the same location on a 1991 5.7L Z?
~Jack~
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
