iac help
Old Mar 15, 2001 | 06:36 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
iac help
I messed with the idle control on my car. I didn't disconnct the iac valve and insert the wire into the a & b connectors. I just messed with the idle screw. If I don't disconnect the valve and do it right can this lead to problems? I'm working on a 305tpi.
85 305tpi Trans am
flowmaster exaust
K&N air filter, 4:11 rear gears
Old Mar 15, 2001 | 06:45 PM
Blade's Avatar
If your idle is fine.. dont worry about it.
92 Z28 5.7
Trick Flow 23° heads, XR270HR-10 cam, Accel intake base + ported TPI, TES headers, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
