No hazards
Old Jul 2, 2002 | 11:15 PM
Kandied91z's Avatar
No hazards
all my lights and electronics on my vehicle work except for the hazards, i pull the switch out and nothing happens........ i would like to have them working what should i do?
Old Jul 3, 2002 | 02:40 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If your brake lights are functional then the stop / hazzard fuse is OK. If your turn signals function, then the bulbs are OK. The problem is either the hazzard flasher, plugged into the "convenience center" - under the dash, right above your right leg, when you are seated in the driver's seat, or the hazzard switch, itself. Try swapping the turn signal flasher (located somewhere under the dash above your left leg) & the hazzard flasher & if the flashers work, the problem is the hazzard flasher. Be sure to swap back the turn flasher, as it's a different type (current sensing) than the hazzard flasher.
Old Jul 5, 2002 | 12:42 AM
Kandied91z's Avatar
will that hurt anything by momentarily swaping them?
Old Jul 5, 2002 | 06:54 AM
ronterry's Avatar
Car: '94 Corvette
Nope...
The turn flasher is just a little slower, thats all...
Old Jul 10, 2002 | 01:58 AM
Kandied91z's Avatar
thanks guys
Twin_Turbo
Mar 14, 2016 10:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Kandied91z
Dec 14, 2001 04:12 AM
MetalliCamaroRS
Nov 13, 2001 09:10 AM
