Fog Lamp switch
Old Mar 19, 2001 | 05:11 PM
johndavid22's Avatar
Fog Lamp switch
I have a 90' Firebird with factory fog lamps the bulbs are good but when you push the switch they go on but when you release the switch they go out. I guess I need new switch. Has anyone ever had this happen, if so where did you find a new one. Pontiac wants $65 for a new switch. Also my switch for the rear hatch does not work and suggestions? Thanks
Old Mar 19, 2001 | 09:05 PM
Vader's Avatar
JD,
The fog lamps are operated by a relay. The switch only controls the relay. The relay is located under the hood, at the extreme left side of the firewall:
The rear hatch is a different system, and the release is directly controlled by the switch. The two circuits have different power sources from the fuse panel, so there is likely no correlation.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
Randomtask2
Sep 10, 2015 08:37 AM
sbrandon
Sep 9, 2015 07:31 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
