Prob with my engine harness! someone stole the damn thing.
Old Mar 21, 2001 | 12:36 PM
vortech305's Avatar
I wrote this in the tech department and a guy is offering to give me his engine harness for free,how about that. Anyway i cant resist that offer but i have a prob. The engine harness is from an 86' T/A (trans am) TPI and was wondering if its compatable with my 88' 305 TPI. i know this probably has nothing to do with it but the 86's didnt come with roller cam as mines does wont it affect the computer so please tell me if the 86' harness is compatable with my 88' computer and 89 mass air flow sensor.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 21, 2001 | 10:25 PM
vortech305's Avatar
thanks for all replies, i appreciate all your help
92' camaro
Soon to come!!!
Other car;
Old Mar 23, 2001 | 01:37 PM
vortech305's Avatar
come on someone help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 23, 2001 | 03:32 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The '86 and '88 TPI systems are both mass air flow sensor (MAS) type systems, but there may be differences in the MAS power & burnoff relay connections - I am not sure - you would need to look at the wiring diagrams in the shop manuals to be certain. In '88 GM went to the single serpentine accessory bracket system & the alternator and A/C compressor changed sides, but that should not effect the ECM harness routing. The T/A harness will be different from a Camaro harness in that the vapor cannister is on the passenger side (driver side for a Camaro), and the battery is on the driver's side (passenger side for a Camaro), so you will have to reroute the power lines from the battery to the fan, MAS, and fuel pump relays, and reroute the canister purge wires to the opposite side, if you use a FB or T/A harness in a Camaro, or vice verca.
Tim
Jorlain
Aug 24, 2022 05:11 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
