Small wire off the - battery cable
Old Mar 25, 2001 | 02:53 PM
SpankuGta's Avatar
Where does this wire go i think it is needed to be grounded but im not sure.Also i have a wire close to the battry that has a fuse stuck in it to make a loop back into the other side i was wondering what this went to it has two wires going into the connector.Thanks for your help.
88 GTA 73k miles
Flowmaster catback,Random tech high flow cat,Ported plentum,Hypertech afpr and air foil,cold air induction,Msd blaster ss coil,cap and rotor and Super Conductor wires.Best ET 1/8th 9.21 at 77 mph.All mods were done within two weeks after purchase.
Old Mar 25, 2001 | 10:12 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The small wire coming from the negative battery terminal goes to chassis ground. The small wire coming from the positive battery terminal usually goes to the alternator output, the fan relays, and the in line ECM / fuel pump fuse.
Tim
Old Mar 26, 2001 | 12:42 AM
SpankuGta's Avatar
Thanks i probably need to ground it my car dosnt charge over 13 with the lights on and the ac going.
88 GTA L98 73k miles
Flowmaster catback,Random tech cat,Ported And Gasket matched Plentum,Base and Runners,Hypertech afpr and air foil,Cold air induction,Msd Blaster ss coil,Cap,Rotor and Super Conductor wires.Just installed LT4 cam.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
