w/ mods done to my car will i need to reprogam my computer.
Or will i need a chip. I plan on getting a procharger later on not now. But for now (see sig. for mods)do i need to do anything to the computer(i hope not)since i changed cam and everything else.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
For now, you may consider an aftermarket PROM to recurve the spark timing & turn the cooling fan on a bit earlier, if you installed a lower temperature thermostat than the stock 195 F thermostat. Also, if your fuel pressure regulator in not adjustibe, get one & experiment with various fuel pressures from 46 to 54 psig, or so; 50 would be a good starting point. When you install a super charger, you will need a custom PROM for that specific application - more fuel & less timing - especially if your TPI setup is speed density (no mass air flow sensor). With speed density, it is more critical to have the PROM calibrations matched to your specific setup, since the ECM has no idea of the actual air flow through the motor. TPIS would be a good choice for a PROM.
Tim
Tim
what prom from from TPIS should i get i know there are certain levels,which one do u suggest. I know there expensive. I have the mass air flow system.
92' camaro
Soon to come!!!
Other car;
92' camaro
Soon to come!!!
Other car;
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I would suggest going to Ed Wright at www.fastchip.com Many people here have used his chips and highly recommend him. Plus his custom chips are only $350 compared to higher prices from other people.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
ill try him thanks
92' camaro
Soon to come!!!
Other car;
92' camaro
Soon to come!!!
Other car;
