Intermittent Radio Power
Old Mar 25, 2001 | 09:02 AM
TA Inov8r's Avatar
I just recently installed a GM Delco Radio in my TA. The radio before had worked, not works, and then worked again - seemingly it had a power problem. This past week it had been raining a lot in Tennessee and I had put on a new antenna. The new radio is now experiencing the same problem - on-off-on-off - with so pattern, rhyme, or reason. I think I may have a short inside the car due to the rain ( T-tops leak from improper seal replacement ) or the fact that their is some sort of grounding issue with the new antenna and mast. I don' t really think the radio is the problem, any ideas?
Old Mar 26, 2001 | 07:30 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Take a look at the clips up inside the fuse panel-if there's been a lot of fuses in & out of there, the fuse clips may be worn out & loose; otherwise your harness might have a loose pin in it. That's all I can really think of.
The antenna shouldn't affect the radio power, the radio has it's own ground lead.
DR Stevens
Car #1: my ride
1984 TransAm
305HO(L69) 96K & counting
750 cfm Q-Jet/Holley rem.
K&N filter
700R4/Superior shift-kit
and trans cooler
3.42 rear/3.73 blew up!!
underdrive pulleys
Accel HEI Super-Coil
180 stat/hi flow water
pump/Jet fan switch
dual snorkel/'84 ram air
3" exhaust of some sort
partial emissions delete
Car #2: My wife's ride
1991 Firebird/Formula
305TBI(LO3) 99K & smoking
K&N air filter
Hypertech Chip
more engine mods later
"Hey, Uncle Sam!! Where's my f**king tax return??!!"
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Aug 27, 2015 11:14 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
