hazards!
Old Mar 28, 2001 | 12:38 AM
Kandied91z's Avatar
hazards!
my hazards have never worked on my 91 since i bought it, everything else works good; any ideas on what could be wrong..........
Old Mar 28, 2001 | 12:54 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If the brake lights are not working, the problem may be the stop / hazzard fuse. If the brake lights are working, the problem may be the hazzard flasher - it is located in the "convenience center", along with the audio indicator & horn relay, under the driver's side dash, or the hazzard switch in the column.
Tim
Old Mar 28, 2001 | 04:18 PM
Kandied91z's Avatar
the brake lights work, is the relay the only other component besides the actual switch?
Old Mar 29, 2001 | 09:08 PM
Yes, the hazard flasher and the hazard switch are the only 2 components in the hazard circuit after the fuse.
Tim
Old Mar 31, 2001 | 04:00 AM
Kandied91z's Avatar
thanks for the help tim
Twin_Turbo
Mar 14, 2016 10:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Kandied91z
Dec 14, 2001 04:12 AM
MetalliCamaroRS
Nov 13, 2001 09:10 AM
