Fan switch?
Old Mar 27, 2001 | 09:53 PM
Stormshadow GTA's Avatar
Fan switch?
How do i go about wirring up a switch for my fans,please be very detailed if possible,when should i turn on and when should i leave it
Old Mar 28, 2001 | 08:39 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
What year & engine?
Tim
Old Mar 29, 2001 | 11:05 PM
87 gta 305 5spd
Old Mar 30, 2001 | 02:31 PM
JPrevost's Avatar
Car: 91 Red Sled
I would also like that info.
My car is TBI so the single fan is controled by it's own temp sensor/switch in the passengers side head. Right now I have the stock fan switch in the head and it isn't hooked up because I have a 160 thermo on the engine. I'm still using the stock relay on the drivers side firewall. The fan comes on with ignition and I don't like that. I'm going to put a 180 thermo in when I reprogram my EPROM and get/build a fan switch.
Tim, do you have any schimatics for making an adjustable temp fan on switch?
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 1, 2001 | 07:32 PM
superz's Avatar
ok lets see, 87, that has only one electric fan right? my 86 only has one and i have a switch like u r talking about. i wired it into the airconditioning pressure switch on the passenger front wheelwell. when the AC comes on the fan comes on too. so when i flip my switch, it connects the pressure switch and my fan comes on. it works great because when i turn off my ignition off it turns off too so i don't run my battery dead. i would give you more exact instructions as to how i did this but my car is at home and i am at school.
86 IROC-Z
40,000 miles!!
305 TPI
1 gutted maf/airbox
2 k&n filters
3 manual cooling fan switch
4 headers, no cat, cat back flowmaster
700R4 tranny
1 shift kit
2 manual converter switch
BF Goodrich radial TAs
3.23 gears
georgous car repainted by my dad and assembled by me
FASTER THAN YOU THINK FOR A "STOCK" 305 hehe.
Old Apr 1, 2001 | 11:30 PM
NO i have 2 fans not one
Old Apr 2, 2001 | 02:53 PM
superz's Avatar
ok i wondered. i couldn't remember which year they switched them.
86 IROC-Z
40,000 miles!!
305 TPI
gutted maf/airbox
k&n filters
700R4 tranny
shift kit
3.23 gears
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
