Please help Intelitronix Guages Flaking out>>>>
Old Apr 6, 2001 | 02:42 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Here is my delima
I have some digital guages (for a long time now) and when the car is off I get ~12.44volts and when turn the motorn on I get ~14.07-~13.90 somewhre in there
I've never had this happen before but, now my guages flake out when car is on but when off it's fine
(I know theres nothing wrong with the guages)
Is that too high Voltage from the Alt. ???
Maby the voltage regulator is going bad???
any info you have would be great THANKS
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Apr 6, 2001 | 09:12 AM
CamaroZ_85's Avatar
nope thats pretty optimal for voltage output...how do you know it's not the gauges?? if your alternator has low output it would catch up with you after a while...lights would get dimmer and eventually you'd turn the key to a dead battery. i dont know how those gauges work, but is there any kind of central power supply??? check for loose wires...
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
