tpi swap
Old Jul 10, 2002 | 08:24 AM
Stoley67's Avatar
tpi swap
I have swapped a 305 tbi for a 305 tpi in a 1991 rs. The tpi harness is out of a five speed and my car is automatic. Where is the tan/blk wire that goes to the aldl connector? The other two wires are present for the tcc being the lt blue and purple. Also the a/c wiring is different in that the compressor only had one black wire whereas my pump has two connector sockets? what can I do?
Old Jul 10, 2002 | 09:46 PM
91 RS's Avatar
what year is the tpi engine?
Old Jul 18, 2002 | 12:18 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
This is funny the wiring harness that i got When i converted is for an auto and i have a 5 speed damn!!!!!
Old Jul 25, 2002 | 02:14 PM
Max_Maro92's Avatar
Car: Purple Haze Metallic 92RS
Engine: Super-ram 383cid
Transmission: race prep 700R4
wiring
well basicall it sounds like the harness you got is for an older f-body. The older models still came with the radial R6 compressor the clutch on an R6 only has one wire. The later years switched to the V4 compressor, two wire clutch with a pressure switch in the back. Options, well you could either get a year correct harness (yeah I know...last resort), If you still have you're old harness you could bastardize it try to use that portion of the old harness and integrate it into the new one, or you could just say f**k it and roll down the windows when it gets hot. As for you're other wires, the best advice I can offer you is first go and find a Howell service manual for TPI, next find out what year the harness ecu and so forth are from. When I did my swap I found the Howell book invaluable, I ordered it directly from Howell. Last but not least you said the donor harness is a five speed harness, the blue and purple wires, are you sure those are for the TCC, they could be the VSS wires
anyway good luck
-mike
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
