Tail light stays on?? WTF?
Old Apr 8, 2001 | 04:12 PM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
When i turn the headlights on my rear left side brake light seems to stay on like the brake is being pressed but the other brake light is working correctly. I figure its probably the socket but im not sure.
Old Apr 8, 2001 | 09:18 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Could be inside the bulb itself. Sometimes the filament breaks off and sticks to the other one.
Old Apr 8, 2001 | 10:30 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Could be a ground somewhere too! I know this isn't the exact same thing but when the ground for my rear defogger came loose everytime I hit the brake pedal, the little rear defogger light on the instrument panel would come one and then go off after I let off the brake!!
Old Apr 8, 2001 | 11:19 PM
87POSGTA's Avatar
Car: 1989 Firebird
Its not the bulb. well i dont think so at least. I replaced them all. all the other sockets look real clean but in this one the Dielectric grease has all dried up and there is some corrosion in it. i cleaned most of the corrosion of but still didnt work.
Old Apr 9, 2001 | 09:01 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Check the ground to the bulb with the brake light filament in it that glows when the running lights are turned on - it's probably open.
Tim
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
Fronzizzle
Aug 19, 2015 01:36 PM
