Altenator puts out 14.4v choke light on 85 Camaro Please Help
Old Apr 14, 2001 | 06:40 AM
scull's Avatar
Have 85 Camaro choke light stays on even when its warmed up. Voltage to choke is 4.46v New heat coil installed in choke. rebuilt altenator checked and its working fine. Need Help.
Old Apr 14, 2001 | 12:26 PM
4SPEED's Avatar
I also have an 86 monte ss and the same thing was driving me up a wall. the coke lite is also affected if the oil pressure switch (on the driver side next to the distributor)connection is weak or loose
Old Apr 14, 2001 | 02:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the choke relay.
Old Apr 14, 2001 | 05:27 PM
scull's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Apeiron:
Check the choke relay.</font>
Where do I find the choke relay
Old Apr 14, 2001 | 07:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's in the "convenience center" somewhere around the driver's knee. Is your choke working at all?
Old Apr 15, 2001 | 07:14 AM
scull's Avatar
It's in the "convenience center" somewhere around the driver's knee. Is your choke working at all?</font>
The choke opens partially on initial startup but does not open fully as the car warms up. It takes about 10 minutes for the choke to open half way. Could you describe what the convenience center looks like. Thanks for the direction Scull
Old Apr 15, 2001 | 09:59 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Did you say the voltage to the choke is 4.46 or 14.46?
Old Apr 16, 2001 | 07:12 AM
scull's Avatar
Did you say the voltage to the choke is 4.46 or 14.46?</font>
Voltage to choke is 4.46 constant.
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 17, 2015 02:00 PM
Omega
Aug 10, 2015 12:46 PM
