how do i swap from comp. controled dist. to vac. advance???????
Old Apr 15, 2001 | 02:08 PM
spitfire350's Avatar
what is the process to wire up the vac. advance instead of the comp controlled unit.
and i already have the non comp carb on there.
thanx for the help.
Old Apr 16, 2001 | 06:43 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
A non computer controlled points / condenser type distributor should have one wire coming out of it. Connect the wire to the negative "-" side of the coil.
Tim
xkingcodex
Feb 12, 2020 07:43 PM
midge54
Jan 29, 2017 07:00 PM
apo_bailon15
Mar 28, 2016 05:20 AM
nuggie
Aug 25, 2015 01:27 PM
tnrednneck
Aug 13, 2015 08:57 AM
