Cooked Modules
Old Apr 19, 2001 | 10:09 AM
89FormulaRoadRacer's Avatar
Cooked Modules
Heres a good one for you guys. I have an 89 Formula 350 w/TPI. The car has extensive modifications using mostly TPIS components including a level 5 chip. The ignition is MSD 6A and Blaster 2 coil. I've moved the battery to the trunk. All of the wiring has been checked and rechecked. I've got good voltage going to the distributor and comuter even during cranking. New battery, alternator, and computer. Here is the problem: The car burns out an ignition module after about 3 days of use. Only the injector side cooks as there is still plenty of spark but no fuel. If I replace the ignition module the car starts immediately. I have now replaced about 8 modules in the course of my troubleshooting. The car sits a lot and is not started for 3-5 days sometimes. Today I ripped out the alarm system that was tied into the VATS with a relay. I'm losing my mind. Once the car is running it is awesome but it is not reliable. There is no hint of trouble whilr the car is running. Only at startup. Anyone have a clue. I would appreciate any help.
1989 Formula 350
Edelbrock aluminum heads
TPIS intake, runners, throttle body, zz-9 cam, level 5 chip.
Ported plenum.
SLP headers and exhaust
MSD 6A, blaster 2
sub frame conn.
bay brace
Hochkis trailing arms, panhard bar.
1LE aluminum driveshaft
Bilstien shocks
Baer Claw Brakes
Old Apr 20, 2001 | 01:41 AM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
This is the module in the dist, right? I do know that you have to put a layer of silicone grease on the bottom of the module to promote better heat transfer from it. It may be getting too hot.
DR Stevens
1984 Trans Am 305HO L69
sucks gas, hauls ***
1991 Firebird 305 LO3
for days when I need a/c
InfernalVortex
Apr 20, 2021 11:31 AM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
RedLeader289
Sep 23, 2015 06:50 AM
