LT1 MAF on a 3rd gen
Old Apr 16, 2001 | 02:52 AM
JJ IROC's Avatar
Does anyone know if it is possible to put a LT1 style MAF on a 3rd gen if the computer is reprogrammed for it? My Car seems to have breathing problems. Even with a modified Stock MAF.
My Car
jjiroc@alijas.net
Old Apr 16, 2001 | 04:42 AM
Vader's Avatar
JJ,
Welcome aboard!
The stock Bosch MAF outputs an analog voltage signal from 0-5VDC. The Delco MAF on the LT1/4 outputs a 5VDC P-P digital signal, frequency modulated from about 5% duty cycle to 80% duty cycle. Unless you want to contruct a D/A converter and scale it for the older ECM, you're stuck with the older style MAF.
If you do a search of the archives on this site, you'll find a lot of data on MAF flows. Even a modified Bosch MAF can have limitations. You might want to check into a Wells SU-145 MAF. It is basically a clone of the LT1 style MAF, except it outputs the required analog signal. It uses teh thick-film sensing element like the LT1, eliminates teh two round wire screens on the inlet and outlet of the MAF in favor of a flat metal matrix (like the LT1), and has no sampling tube or heat sink fins in the air stream to impede flow, like the LT1. It also has a slightly larger I.D. than the Bosch MAF, and a minimum of 73mm at the smallest point and 78mm at its largest, as opposed to 70mm on the Bosch unit.
Directly plugs in and is scaled for the ECM, right out of the box.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 16, 2001 | 05:44 AM
JJ IROC's Avatar
Thanks Vadar any clue where I can get the wells.
My Car
jjiroc@alijas.net
Old Apr 21, 2001 | 05:06 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
You can get the Wells MAF from World Discount Auto Parts ((800) 288-6728 Ext 115) for about $160 last time I checked..... Ask to speak to Tom Martin I believe.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 21, 2001 | 10:06 AM
BLOWN85/TA's Avatar
Check this url for Super Mod Vader's big post on this subject, more info inside.
https://www.thirdgen.org/messgboard/...ML/002288.html
midge54
Dec 27, 2019 04:14 PM
Warlocksirix
Sep 3, 2015 12:26 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
