What is a good code reader?
Old Apr 18, 2001 | 09:53 AM
purpleworm's Avatar
I want to by a good GM diagnostic tool. Does anyone ahve any suggestions?
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit
One sweet sounding system
Old Apr 18, 2001 | 03:51 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
$20 Bucks. WalMart auto section. Hooks directly to the prongs where a dealer would hook the diagnostics tool up to. Comes with manual to explain codes. Codes are pulled after this piece is connected, and by the service engine soon light flashing a certain number of times. Example: "flash, pause, flash, flash"...code 12-ECM check. Its all in the manual. Very easy to understand and use. There is also a tech article on this board that gives you all the trouble codes, and a diagram to show you how to use a paperclip to get the same results. Hope this helps.
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old Apr 18, 2001 | 08:50 PM
Vader's Avatar
Worm,
I'll sell you a "code reader" for a lot less than $20.00. Check this file for all instructions and decoding, and get two paper clips (one to hold together the printed sheets, and one for the "code scanner":
GM Error Codes.pdf
You'll need Adobe Acrobat Reader to view/print the file (see link below).
Later,
Vader
"What a Day..."
Old Apr 18, 2001 | 11:52 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Vader...
I know you dont like my Code Reader promotionalizing Thats why i also mentioned the tech article...something i should have looked at instead also
Megs Custom 4.5" Stainless Steel Rolled Tips
OTHER RIDE:
12/14 Options
Stock(for now)
Old Apr 19, 2001 | 08:34 AM
purpleworm's Avatar
I know all about the aldl connection and how to read the codes but I was hoping to get a better tool to see what the computer is doing. I would like to see exactly what the car is telling the sensors and vice versa. I am thinking of getting into burning chips but I am still collecting info from posts. It will take me awhile.
91 Z28 Camaro
305 TPI
Old Apr 22, 2001 | 01:58 AM
Vader's Avatar
Diacom has a decent package for actively reading the ECM data bus, but it's a lot more than twenty bucks, and I don't think you'll find one at WalMart.
Later,
Vader
"What a Day..."
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
