Solid Check Engine light, not going into closed loop (long)
Old Apr 22, 2001 | 03:50 AM
EvilCartman's Avatar
Car: '82 Z28
The subject: '82 z28 with the carbureted 305, comp cams xe256h, edelbrock performer intake and TES headers.
Problem: Check engine light stares me in the face and laughs all day long. ECM Will not go into closed loop.
History: Problems first began a few months back with a flickering check light. The flickering then turned to an always on situation. I tried the paperclip diagnostic tool to pull a code but the check engine light still stays solid.
The past month and a half my car has been to two different shops in town (a third one come Monday) trying to figure out what's going on. So far, the computer has been replaced 4 times and 3 new chips have been installed trying to track down the problem.(stock one is back in) Both places have given up on solving the problem. I know for a fact they have replaced the O2 sensor, checked and fixed vacuum leaks, probed wires, and have had a look in the distributor. They've checked grounds and at one time had 14 grounds to various places but still no change. The scan tool one of the shops tried using, couldn't get any info from the computer.
I only have till the end of the month to get this thing running right so I can pass smog here in California. Right now it's running full rich and the distributor isn't getting advanced by the computer. The last owner lived on the coast plus the T-tops leak, so there is a question of corrosion. I've checked under the dash a bit and it's not too bad looking. Just some surface rust on the bare metal.
Any help would be much appreciated.
EDIT: After just reading what Vader said in another thread about how the check engine light turns on and off, shouldn't the light stay off if the ECM is pulled? Mine still comes on even with the ECM pulled. hummm
[This message has been edited by EvilCartman (edited April 22, 2001).]
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
