bad computer?
Old Jul 18, 2002 | 01:46 PM
icemanohio69's Avatar
Car: 2000 xtreme
Engine: 4.3L
bad computer?
i am currently swaping from tbi to tpi im using a painless wire harness im using a used computer out of an 89 firebird with a hypertech chip for an 88 camaro i have spark and fuel pressure but my injectors have power on both sides no pulse could this be bad comp? thanks in advance
Old Jul 18, 2002 | 04:28 PM
2vmodular's Avatar
did you install the VATS module out of the donor car? without a fuel enable signal, a vats enable ecm will not pulse the injectors.
see this thread for more details:
https://www.thirdgen.org/techbb2/sho...hreadid=118472
Old Jul 18, 2002 | 11:15 PM
Car: 2000 xtreme
Engine: 4.3L
ok tell me if im wrong im not so good at electrinics if i use the chip for an 88 camaro cause they dont have the vats i think and if i bypass the starter enable relay that should take care of the vats rite?or am i missing something oh and if someone could tell me a simple way to bypass the starter enable relay that would be alot of help
the only thing i used was the computer and the intake & runners maf stuff like that i bought it off e-bay i had to buy a painless harness
thanks for the reply
Old Jul 19, 2002 | 11:08 AM
2vmodular's Avatar
in 89' most (??all??) of the tuned port camaros were vats equipped.
bypassing the vats starter enable relay will get the engine cranking. but won't get fuel flowing to it because the injectors will not pulse.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Johnoooooo
Sep 22, 2015 08:55 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Stryker412
Sep 7, 2015 09:11 AM
