Tach question...Tim??
Old Apr 27, 2001 | 04:57 PM
theformula's Avatar
I know the factory tach is off (usually reads lower than actual RPM by 1000RPMS). So if I use a MSD shift light and set it at 5000 RPMs, is it really lighting up at ACTUAL 5000? Or is it working off the factory tach? I have it plugged in to the output of my MSD6AL
thanks
Old Apr 27, 2001 | 06:04 PM
tpsierra's Avatar
If it reads lower by a set amount (1000 RPM, for example), the tach is ok, and the needle has to be reset on the shaft up by that set amount. The needle usually come off easily on the tach, but be careful, I have ruined many a gauge trying to pull off needles. Oh, the ignition module works independentely from your tach, so you are ok.
1957 3/4 rat
1966 c10 panel
1968 c20 350, 350
1982 camaro 305, THM-200-R4
1984 Monte Carlo, 350, th-350
Everett, WA
[This message has been edited by tpsierra (edited April 27, 2001).]
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
