where to plug in the power for the MSD ??
Old Apr 28, 2001 | 08:55 PM
james_fearn's Avatar
I did a search and the only direct MSD topics only listed to draw power for the MSD unit from the alternator stud. MSD says that is not the way to go. Any other suggestions??
James
1985 Z-28 305 TPI 223,000+ mi., Original Eng.,T-Tops,Blue/Grey
STB,SFC,GW "wonderbar",145 Speedo
Old Apr 28, 2001 | 09:33 PM
Blue91''s Avatar
I got power to my MSD box right off a terminal junction that is directly off the battery. If you follow the smaller wire that comes off your battery cable , positive side you should have a small terminal post next to the radiator. You shouldnt run the power for your MSD off the alt. I did the same for the ground as well. Hope this helps
Old Apr 29, 2001 | 05:06 AM
93ND500's Avatar
Got mine running straight off the battery. To keep things safe I put a 30AMP inline fuse in right at the battery.
BRoss99
Aug 10, 2025 05:08 PM
Bert87
Aug 23, 2015 03:50 PM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
