Check engine light
Old Apr 27, 2001 | 07:04 PM
Tonyrodz's Avatar
Transmission: auto
Check engine light
OK I'm still trying to figure out all of the electrical problems on my swap(still doesn't run)I can't get any kind of check engine light-nothing- all fuses are good and the ecm is getting power. I have a noid light(test light for injectors) to see if the injectors are pulsing on when it cranks--they don't. Anybody have any ideas? I'm lost!
It's an 86 T/A, had the 305 tpi in it-went w/a 350 tpi(and trans)from my 89 Formula--switched everything! All wiring(body, dash, etc) so basically it's an 89 w/an 86 title.
Any help appreciated.
Old Apr 27, 2001 | 08:01 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Did you connect the 2 ground straps from the harness to the back of the cylinder heads?
How about the engine to chassis ground?
No ground = no connection/bad connection...
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
Old Apr 27, 2001 | 08:10 PM
Tonyrodz's Avatar
Transmission: auto
I didn't put the harness in myself but I do know the strap on the pass. head is a little loose(very little play). I've tried to tighten it but I can't get in there--any suggestions? I've even tried from under the car w/no luck. Where's the other strap located? Haven't seen it.
Thanks for the ideas! I've been wracking my brain.
Old Apr 28, 2001 | 02:06 PM
Tonyrodz's Avatar
Transmission: auto
Any other ideas?
Old Apr 28, 2001 | 11:51 PM
bruhaba's Avatar
did you install the vats correctly?
obviously the engine will not run without the correct resistance value on the pass-key module.
Old Apr 29, 2001 | 02:56 PM
Tonyrodz's Avatar
Transmission: auto
I thought it could only go in 1 way? If it was installed wrong would that have anything to do w/no engine light?
Thanks-
Old Apr 30, 2001 | 11:18 PM
Tonyrodz's Avatar
Transmission: auto
bttt??
Old May 4, 2001 | 07:40 PM
Tonyrodz's Avatar
Transmission: auto
ttt
Old May 7, 2001 | 01:49 PM
MAXGTA2002's Avatar
Hey Tony, I did the same change with a 91 350 that had vat's,in to my 86, I used the 305 computer and wiering that was allready there,I had to change a location of the oil sending unit and changed the injectors but other than that the car runs good, now there is three grounding wires on the passenger side as somebody mentioned and two on the driver side,on the back side of the heads that need to be grounded to make the harness work, if the check engine light worked before it should work. hope this will help some.
Old May 7, 2001 | 03:49 PM
Tonyrodz's Avatar
Transmission: auto
I ripped out the complete under dash harness--it was a mess! Thanks I'll check out those grounds on the driver side head. On the pass side the ground on the head is a little loose--looks like they didn't use the right size nut, think that would have any negative effect? The car might as well be titled as an 89--everything is from it! Only thing that's from 86 is the chassis!
Also the glass fuse near the battery(inline fuse)was blown.
[This message has been edited by Tonyrodz (edited May 07, 2001).]
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
