High hatch-mounted third tail light install in spoiler-mounted light equipped car.
Old May 8, 2001 | 12:40 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I had to get a replacement rear hatch for my '88 and I managed to pick up a '91 hatch in great shape for nothing. The hatch has the high mount 3rd tail light, and my '88 has the spoiler mount tail light. The harness I got with the hatch (from the dash to the light) has a 4 pin plug (ground, orange, white, and then a wire for the high tail light) and also supplies the lighted rearview mirror. I put a lighted rearview in the '88 but I believe it only has 3 pins in the plug (ground, orange, and white). I have all the wiring to run to the new light, but is it just a "plug it in" thing or do I have to change the harness under the dash too? My '91 is 3 states away so I can't get to it to check for myself. Also, will the spoiler mounted light still work when I switch the hatch? I'd like to run both. Thanks..
Ed Miller
Charlotte, NC
1991 RS, 305 TBI,
bone stock driver;
1988 IROC L98
TPIS Fast Pack, modified MAF, MSD 6A, Dynomax cat-back so far.
"Do you want to race or don't ya? I want to race." Dale Earnhardt
Old May 8, 2001 | 12:50 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I probably can't help you out too much, but you may have a wire harness difference between the 2 cars. I have a '91, but have not been into the brake light wiring. I think some wire harness changes were made for the 89-92 cars, versus the 86-88 cars. I can look in my book tonight, but by then you'll probably have another answer to your question...
KAM
Old May 9, 2001 | 04:02 PM
ebmiller88's Avatar
I checked last night and the "dash" plug as I call it has 4 wires, orange, white/orange stripe, gray, and yellow. The yellow wire is for the tail light, the gray for the lights in the rearview mirror, and orange and white/orange to the dome light. I will probably have to tap into a brake light wire somewhere and run it into the harness. I'm still waiting on a parts and illustration manual I ordered or I would have checked already. Thanks for the reply..Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 19, 2015 01:36 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
