Door lock questions
Old May 11, 2001 | 07:04 AM
custman87T/A's Avatar
Door lock questions
I finally got around to looking at the problem with my power door locks. Neither one works no clicking or anything. I lubricated both and put new switches but still no locks. I took my volt meter and I have power at the switch in the middle terminal but when I press the lock or unlock button both sides of the harness to the lock mechanism gets power. I looked at the wiring diagram and it appears that it should switch the power to one side or the other when using the lock/unlock button. I checked continuity at the solonoid and both sides of the solonoid are in continuity with each other which appears to be causing the power to go to both sides of the motor. What should I look at next?
Old May 11, 2001 | 12:44 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Have you checked the relay ?
Old May 11, 2001 | 01:51 PM
I checked the relay as far as getting power to and from after the switch is pressed I get power out of both sides of the relay 14 volts to lock and unlock. I don't know too much about the relays but does this mean I should replace it. I am not one to just throw parts at a problem.
Old May 12, 2001 | 06:49 AM
Imark's Avatar
On my '84 Z28 the relay grounds to the body. This would reflect voltage at the relay and the switch but it won't complete the path with out the ground. I'd check to make sure the relay body it grounded. Just an idea.
"It's not about going fast all the time; It's knowing you can, anytime"
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
g.l.mos
Aug 22, 2015 12:02 AM
