Tach WAAAAAyyyyyyy off
Old May 14, 2001 | 12:12 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
A long time ago I thought it would be cool to make my Tach Needle a different color. I took it off, sanded off the orange crap, and applied dark purple tape (my car is purple). I put it back on and wasnt too impressed. I later found out that the tach was about 1000 RPM off. At idle, it would read 2000! I finally got around to replacing the needle today, and now it is even worse. When I first start the car, it will idle at about 1000, which is correct. When I am stopped at a stop light, the needle nearly drops all the way to 0, when it should be at least 6-700. When I put the car in park, it falls to 0. Did I break the Tach? Can this be fixed? Thanks guys!
Old May 14, 2001 | 12:41 PM
tpsierra's Avatar
Did you add a bunch of weight to the needle? They are balanced so that they exert no torque on the mechanism. If you did, take off the purple tape and try it.
Old May 14, 2001 | 01:33 PM
Scott_92RS's Avatar
Car: 1992 RS
I put a new stock needle (orange) back on it. The purple one is no longer there.
Old May 14, 2001 | 10:18 PM
tpsierra's Avatar
well? did that work?
Old May 16, 2001 | 02:46 PM
Scott_92RS's Avatar
Car: 1992 RS
Maybe I explained what I did wrong. I'll try to be clear this time.
1. I took off the needle, made it purple
2. Put needle back on, 1000 RPM too high
3. Took needle off, put a stock needle back on
4. Needle is wayyyy off again. Idles ~1000 RPM at startup, 0 RPM when I stop the car again after driving it and put it in park.
I need to fix this. I'll be selling it soon, and I dont want anything wrong with it.
Thanks guys.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
