Need help...VATS mystery/no start
Old May 17, 2001 | 04:07 PM
MILT's Avatar
Howdy; I got a problem--my '91 T/A won't start. When I put the key in and turn it, the SES and security lights come on--and stay on until the key is turned to the off position. Everything else seems fine. I tried measuring the resistance in the key and comparing it to the value in the wires, but the value doesn't change (well, possibly by 1 ohm).
Since the security light stays on, and the resistance in the wires is the same as the key, am I right to assume that the key I have has the wrong resistance code?
Where do I go from here???
Thanks in advance for any help...
MILT
[This message has been edited by MILT (edited May 17, 2001).]
Old May 17, 2001 | 07:06 PM
MILT's Avatar
Come on--I've read through archives, don't know what to do next. Would appreciate some help...
Old May 18, 2001 | 06:02 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If the key worked at one time, then it has to be the correct value, and the problem is elsewhere. If the resistance value measured at the colunmn harness is the same as the value measured at the key, then the problem is between the column and the VATS module, or the VATS module, itself.
Tim
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
