JET fan switch...easy to install??
Old May 23, 2001 | 08:26 AM
NOCANDO's Avatar
Im planning to install a JET Fan Switch on my 92 Camaro. Does the switch come with its own wire harness and is it easy to install. I accidently broke off the connector off the stock fan switch. Checked with GM parts store and they only sell the sensor without the connector.
Old May 23, 2001 | 11:18 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Yep, same as before... just remove your old switch (you might get a little wet) and put in the jet switch. It will come with a connector, but if it doesn't, e-mail me and I'll send you the one I have. Or do you just want the connector, and replace the switch?
KAM
I just realized you're in Guam... that'll take forever to get to you probably...
[This message has been edited by thunderstick (edited May 23, 2001).]
Old May 23, 2001 | 05:55 PM
NOCANDO's Avatar
Thanks for the advice. I think Ill get the JET fan switch. The only problem now is Summit has it on back order til June 4th. Seems like Ill have to wait and jimmy rig the one I have. Its not so bad in shipping to Guam. It takes about 7 days if I order from Summit....
Old May 24, 2001 | 07:10 AM
Car: '91 Z28
Axle/Gears: 323's
Try Jegs - they have them, too...
KAM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
fasteddi
Sep 2, 2015 10:29 AM
Firebird sweden
Aug 16, 2015 05:02 PM
TA8487
Aug 16, 2015 12:21 PM
