Fuel Gauge question and ideas
Old May 16, 2001 | 09:51 PM
XxMoLexX's Avatar
Ive had a bustd fuel gauge for 2 years and im finnaly ready to change it. Im pretty sure its just the sending unit. because the gauge lays down on the FULL side untill i get towards the end of the tank and then it starts to swing when i come to as top and such.
My question is, when i go to fix it, and replace the sending unit, should i replace fuel pump ?... i dont want to have to do this again incase some day the damn thing decides **** on me. another idea i had was to put in an Autometer fuel and maybe pressure gauges, but i dont really need it. BUt i thot the aftermarket gauge would be more reliable and more accurate and it will help to dress up the interior of the car a little.
Bad idea?
91 3.1 RS.
T-Tops
12" tube in the "trunk" (That hole they call a trunk anyways)
16x8" ROH Rims
Firehawks all Around
New BOSCH plugs and wires.
Itchin for a SLP Cold Air and new catback.
Dynomax or American Thunder... dunno yet.. suggestions?
Old May 24, 2001 | 04:03 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Great idea to replace your fuel pump. It can't hurt at all. Even aftermarket one would be great if you plan on doing mods in the future. For an aftermarket fuel level gauge...do whatever tickles your fancy...for me, the stock one works fine. You can go in and adjust the needle if it bugs you too much. (They're off a little from the factory) For fuel pressure, you're going to need an electronic guage if you want it to be in the interior of your vehicle. I have a digital intelletronix one in a guage pod on my a pillar. However, you can add that at any time just by plumbing in a sending unit under your hood. Good luck changing the sending unit!
Mint black/black 1987 T/A GTA 305 5-speed, 55K,
3.45 factory POSI,SLP cam, SLP runners, Taylor wires, hurst comp plus shifter, K&N conical rig, AFPR, coated shorty headers, no cat, no smog, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 160 stat, SFC's, lower control arm adapters, Aluminum Driveshaft, ported upper and lower, Mobile ES and 10 disc, kickers all around and q-logic kick panels...Perf 350, rear batt, lowering springs,cowl hood, & NOS coming soon!
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
redmaroz
Aug 16, 2015 11:40 PM
