A/c Unit not engaging when level is switched on
Old May 23, 2001 | 09:10 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Last year The A/C unit in my '85 z28 5.0 was serviced. Everything recharged and running great. Towards fall, I could hear the bearings in the unit rattling around. Short of putting wear and tear on the unit over winter, I took the belt off. In this 98 degree heat wave here I put the belt back on. Switched the lever to max a/c the pulley turns but the unit clasp in from that grabs onto the pulley, isn't engaging. Fuse is good. All connections good. What goes on?
Old May 24, 2001 | 07:16 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There is a low pressure compressor cut out switch in line with the compressor clutch coil. If the charge in the system is low, the switch will not allow the compressor clutch to engage. The switch is located on the accumulator, on the passenger side. There are a set of '85 schematics on line at:
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Tim
Ghettobird52
Jul 5, 2024 11:18 PM
777Shock777
Oct 29, 2015 04:30 PM
5spdcamaro
Aug 28, 2015 02:12 AM
355sbcTPI
Aug 19, 2015 04:38 PM
ZsTransAm
Aug 11, 2015 07:30 PM
