Would My Car Benefit From A High Output Aftermarket Coil?
Old Jul 29, 2002 | 05:38 PM
1991 RS 305's Avatar
85 305 TPI. Stock with typical bolt on & free mods. Since most seem to feel that MSD's are a waste without major mods, would a high output coil ( mines coil-in-cap style) make a noticeable difference in any way? Or is the stock Delco coil sufficient? I've got new Delco cap & rotor, TPIS wires & Bosck 4's. I'd like a smoother idle and more throttle response if possible. If so, what brand do any of you out there prefer? Thanks in advance!
Old Jul 29, 2002 | 10:11 PM
Jza's Avatar
Jza
Only a small and unnoticable gain could be attributed to a high output coil on a relatively stock motor. Any improvement you notice will actually be from replacing a weak coil with a new one.
I personally don't feel that MSDs are a "waste without major mods". If you plan on having a healthy motor later, then it's merely the difference between making your bed in the morning or making it right before you get in.
Still, don't drop a couple bills and expect a noticable improvement right off the bat. That's where the "waste" perception comes in.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
L98GTA87
Aug 5, 2015 11:02 PM
