Tach Calibration
Old May 25, 2001 | 07:21 PM
Rough84Z's Avatar
Tach Calibration
I recently purchased a replacement gauge cluster for my '84 Z cause some of the needles were broken off of the old one. Everything seems to work properly except that the tach reads really low as compared to the old one. I believe that the old one may have come from a car with a 6 cyl. instead of a 8. Can anyone tell me, if I transplant that little yellow box from the back of the old cluster onto the replacement, will that cause my tach to read as it should? If not, how can I correct the problem?
Thanks in advance.
Old May 29, 2001 | 06:58 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If you use a 6 cyl tach to read the rpm of an 8 cyl engine, the tach will actually read 25% higher ratio than the actual engine rpm. Sounds like your tach needle may need to be repositioned, if the tach error is a fixed value & not a ratio.
Tim
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
