hatch release acting like remote starter switch
Old May 29, 2001 | 10:11 AM
Bill Ostrander's Avatar
need help with any ideas on what might cause this problem it has overridden rhe hatch release and now it does'nt engage as if there in no power going to the unit.Any ideas or a wiring diagram would be useful
thanks
Old May 29, 2001 | 10:24 AM
it's a 89 camaro rs w/a305 tbi
Old May 30, 2001 | 01:08 AM
Omar's Avatar
This is an automatic? If so, the hatch release relay is grounded through the purple wire that goes to the starter solenoid. This is the same wire that gets 12 volts to the starter from the ignition switch when in the forward start position. Your ground connection has been broken somewhere. Have you installed a remote start/bump switch in your engine bay, or alarm/starter kill switch recently? A diagram would definitely help, someone will post one shortly.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
BRoss99
Aug 10, 2025 05:08 PM
Street Lethal
Apr 30, 2019 12:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
neekolzun
Aug 24, 2015 04:59 PM
92camaroJoe
Aug 13, 2015 06:07 AM
