ignition "clicking"
Old Jul 31, 2002 | 01:37 PM
92camaro1's Avatar
ignition "clicking"
Here's the issue at hand. I know what's causing it, just not exactly how to fix it. My 92 camaro has that stupid chip in the key and well, it's not making 100% contact when I insert it in the steering column. You'll hear the "click, click, click" as I attempt to start the car. There is a way to bypass this sensor, effectively disabling the chip on the key. I know you have to disassemble part of the steering column to do so. I just need to know the specifics on how to bypass it. Do I just bypass it, or ground it?
Old Jul 31, 2002 | 04:55 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Look in the technical article section here. You don't have to disassemble the column. I believe there is a plug that you can jump with a resistor. You are referring to the VATS anti-theft system. The pellet in the key is actually a fixed value resistor. In the tech article section it is well explained.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
