Newbie Question
Old May 29, 2001 | 12:41 PM
cc92's Avatar
Newbie Question
Just picked up a 92 RS v8 5.0l.
It was running very hot so I changed the thermostat. Now it runs lots cooler (around 175). I'm wondering about the cooling fan. Is it supposed to run when the engine is off? or only when its running and reches high temp. I ask because when I shut off the engine the gauge redlines but the fan doesn't come on. Thanks all.
Old May 29, 2001 | 02:33 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Welcome and No. The fan will shut off when the power is shut off. As soon as you shut the motor off, you no longer have circulation of coolant through the engine. Thats why it will end up red lining. But even then it should'nt readline. You may have a deeper issue than you think. Hope that helps and good luck!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old May 29, 2001 | 07:29 PM
cc92's Avatar
Thanks, I want to make sure its on when the engine is. Other problems? Such as?
Old May 29, 2001 | 07:39 PM
cc92's Avatar
<font face="Verdana, Arial" size="2">Originally posted by cc92:
It was running very hot so I changed the thermostat. Now it runs lots cooler (around 175). I'm wondering about the cooling fan. Is it supposed to run when the engine is off? or only when its running and reaches high temp. I ask because when I shut off the engine the gauge redlines but the fan doesn't come on. Thanks all.
</font>
Old May 30, 2001 | 01:36 PM
CraZ-28's Avatar
Car: 1991 Z-28
Well, if it's redlining when you shut it down, that's not good. It might be time to change the collant in the system. Also, there is the possiblity that you may have a gauge that is reading incorrectly. Those are just some of my thoughts though, but it still should not redline. Just some things to consider. Good Luck!!
Old Jun 4, 2001 | 04:27 PM
cc92's Avatar
Good advice. I finally broke down and bought a new water pump. Installed it (very fun). Car runs lots cooler, fan turns on around 210. Doesn't redline when off anymore either. Thanks again.
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
R3500
Aug 24, 2015 09:05 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
