Window motor problems
Old Jun 2, 2001 | 10:33 PM
butgoblin's Avatar
Can someone help me? The driver side window in my 91 RS is screwed. I can roll it up or down only about 3 or 4 inches then it will stop moving. Then i have to let it 'rest' or cooldown for about 5 minutes before trying to move it again. I really need to get this fixed.
Old Jun 3, 2001 | 10:28 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
easiest way to fix it is to replace the window motor... have someone else do it, if you need to, or there's a tech article on this board for it...
KAM
Old Jun 3, 2001 | 03:00 PM
Stuart Moss's Avatar
Do a search for "window motor" or "window" under this forum. Your problem has been covered extensively by many, many posts.
The tech article should cover anything left out by those posts.
Old Jun 4, 2001 | 11:34 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
From experience, I can honestly say, window motor. I prefer doing in in pairs when they're both old, but that can be expensive and annoying. You obviously know you have power...
Old Jun 5, 2001 | 06:50 AM
Vader's Avatar
BG,
Before you drill/grind the rivets, check this idea:
Power Window Motors.pdf.
You'll need Adobe Acobat Reader to open/print the file (see below).
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
stalkier
Aug 13, 2015 12:59 PM
