Analyzing scan tool data
Old Jun 5, 2001 | 11:44 PM
AFRO IROC Z's Avatar
I hooked a snap-on scan tool up to my iroc today. I don't know what all the numbers are supposed to be, that would indicate that my car is running properly. I know what the tps is supposed to be, but some of the others i don't know, like the BLM was 149 but is supposed to be 128( how do i get it there. What should the oxygen sensor volts be, what are cross counts what should they be. My car would be in closed loop for a while and then go into open loop for about five seconds and then would switch back to closed loop again. It spent most of its' time in closed loop though. is that bad. Where can I find all this info, learn how to analyze it and make adjustments accordinly. Thanks for any help.
Old Jun 7, 2001 | 11:22 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Get a GM Factory Manual for your Camaro, don't use those auto store books they suck, a factory manual will tell you what all those numbers mean and what they should be and what to repair.
Old Jun 9, 2001 | 11:42 PM
If no one can help me in here could some one tell me where I could possibly find an answer. Thanks
Old Jun 14, 2001 | 08:55 PM
Jza's Avatar
Jza
<font face="Verdana, Arial" size="2">What should the oxygen sensor volts be, what are cross counts what should they be. </font>
the oxygen sensor voltage should be flying all over the place as the computer is constantly adjusting the a/f ratio. cross counts is simply how many times the o2 sensor voltage swings up and down past 500mv.
<font face="Verdana, Arial" size="2">It spent most of its' time in closed loop though. is that bad. </font>
closed loop is good.
<font face="Verdana, Arial" size="2">, like the BLM was 149 but is supposed to be 128</font>
BLM sort of indicates whether the comp. is adding or subtracting fuel >128 means it's adding. at idle it's gonna be higher because it's lean.
Falcon50
Aug 22, 2020 03:26 PM
92projectcamaro
Dec 8, 2015 12:25 AM
Reid Fleming
Oct 10, 2015 09:56 PM
bjpotter
Oct 4, 2015 07:48 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
