Intermittent Electrical Problem -- Car Dies
Old Jun 15, 2001 | 09:48 AM
Stoopalini's Avatar
I dunno what's going on here, but I hope someone can offer some insight into my problem.
The car is intermittently loosing all power. When I say all power, I mean it's like the battery becomes disconnected while I'm driving. I loose all my radio pre-sets, and the car just shuts off. The tach even stays at the same spot, it does not drop down to 0.
When this happens, I put the clutch in and wait. After apx 5-30 seconds, the power comes back and I can either pop-start it, or turn the key to start it back up.
I've checked the battery connections and they are fine. I even started the car up and wiggled all of the hot wires coming off the distro block next to the radiator, but it never hesitated.
It seems like a loose connection, but I can hit all the bumps/pot holes in the road and it doesn't cause the problem to happen.
Could a dead cell in my battery cause this?
Anyone have any advice for me?
Thanks,
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- 3.08 geared rear
1.6 Roller Rockers / Adjustable Fuel Regulator with high flow pump / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip / MSD ignition
Headers - Flow Master - dual chrome tips
adjustable Coni shocks & struts
Old Jun 15, 2001 | 12:50 PM
Stoopalini's Avatar
Well, I'm pretty sure I found my problem. I went out for lunch and it died on me again. This time it would not start back up. I opened the hood and start playing with the wire that goes from the distro block to the starter, and power came back on. It seems I have an internal break in this wire and needs to be replaced.
Just thought I'd share
Thomas.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
