dist. removeal?
Old Jun 7, 2001 | 03:16 PM
Matt's Avatar
dist. removeal?
Can I get a step by step on how to do it and any thing i should look for/tricks to make it easier.
Old Jun 8, 2001 | 12:04 PM
MAXGTA2002's Avatar
what are you acually doing with the dist?
If you pull it out, put your timing mark on
TDC O, Then pull the dist cap to make sure were your rotor button is pointing,pull it out you may have to adjust the oil pump with a long screw driver down inside to the dist go back the same it come out put it back the same way the rotor was pointing, put the cap on plug you wires up, crank it up, unplug the brown and black wire above your blower fan, set your timing, tighten the dist down, plug the brown and black wire back up. unpluged it should read your timing degree (6) or what ever yours calls for and when you plug it up it will probably change but thats ok. just make sure that you set it with the brown and black wire unplugged
Old Jun 10, 2001 | 12:07 AM
Matt's Avatar
replacing the cc dist. with a non cc dist.
Old Jun 14, 2001 | 04:11 PM
Matt's Avatar
Old Jun 15, 2001 | 03:07 PM
MAXGTA2002's Avatar
well just to swap it out thats what you need to do it doesn't mater what type your going to use. as long as it is for the same engine.
[This message has been edited by MAXGTA2002 (edited June 15, 2001).]
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
