horn problem
Old Aug 6, 2002 | 09:19 PM
muffler's Avatar
horn problem
the horn on my 88 camaro went **** up. dont have the wirings schetch. any1 know how to check if its the horn or the wiring and how. pse help.
Old Aug 7, 2002 | 04:58 PM
racerx004's Avatar
First, check to make sure the fuse isn't blown.
If not, use a test light or a multi tester to check and see
if you are getting power at the horn when you try to honk the horn.
If your not getting power, then the rellay may have gone bad.
Old Aug 8, 2002 | 09:38 AM
Morley's Avatar
The 3rd gen horns were flakey at best. If the fuse is blown your lighter and power door locks won't be working either. The contact ring in the steering column is most likely the problem. Pull the steering wheel, then carefully pull the black plastic shroud under it. Under there you'll see a brass ring with some tabs on it, if it has shifted the tab that goes under the horn connector won't be there any more. You'll need to play around with the ring to get the tab back in place, once you get it back in place superglue the ring in place on the right side so it can't slip any more.
Old Aug 9, 2002 | 10:41 AM
RsCamaroIHave's Avatar
Where is the fuse for the horn ..i think mine is blown ... but i dont know where its at
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
