Installing 4th gen power seat.
Old Aug 8, 2002 | 02:24 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
I just got some 4th gen seats out of a 99 camaro. leather and dark grey. How do i hook up the power seat on the driver side? I know i have to run a constant power to soemthere in the car and the ground. but where do i run the power constant?
Old Aug 8, 2002 | 05:57 PM
Desert86Roc's Avatar
I just cut the connector out of the donor car, and wired it to my existing harness. Many cars without power seats had the wires under the carpet for them.
If not, just wire directly to a battery hot (in fusebox would be good) using an inline 20amp fuse, and then ground to the body. Should work fine.
Old Aug 10, 2002 | 03:24 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
I wired directly into the cigarette lighter with a T connector available at any radio shack. I ran the wire under the center console under the carpet to the bolt holes and than connected to the harness on the seats. If you don't have the original harness im not to sure what you can do. Never had that problem
James
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
