weird one! -digital dash
Old Jun 26, 2001 | 12:14 PM
Andrew H's Avatar
I recently retro-fitted a digital dash, but the odommeter/computer part I'm sure is faulty...
when you switch the ignition on, it all lights up and then the computer sections fades-out after about 30 seconds...
It does this each time you switch on the ignition, but if it's just been on it'll only then come on for about 3 seconds -it's not the display part as when it's off it won't record mileage either
I think it might be faulty capacitors, but seems unusual -any ideas!?
thanks!
Old Jun 26, 2001 | 01:04 PM
MAXGTA2002's Avatar
check to see if you are putting pressure on the lense cover, mine did the same thing and the clear lense was off setted wich the plastic frame was aplying pressure to it. for example apply a little pressure on the lense to see if you destorts it. this sounds odd but it happens.
Old Jun 26, 2001 | 02:25 PM
Andrew H's Avatar
thanks -I'll try that, but think it might be something more sinister!...
Old Jun 26, 2001 | 02:56 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Check the cluster light & dimmer control inputs - they control the readout brightness level.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
