TC lockup problem, please help???????
Old Jun 18, 2001 | 09:02 PM
PPonU4Me's Avatar
I need to make a manual lockup switch for my '87 Iroc. I have disconnected the ECM, so the tech article that uses the ALDL doesn't work for me. I would really like to stay away from the kits, I just want a toggle that I can control myself. Any help or suggestions would help. Also, If I try to hook up the ECM, it just blows the guage fuse, if you have any ideas on how to stop this, then I could hook it up through the ALDL. Thanks.
'87 Camaro Iroc-Z
'92 350 .040-over
Mild Cam
700R-4 w/shiftkit only.
Edelbrock Perf. manifold and Holley 750w/vac. sec.
GM HEI upgraded with Accel parts
TBI truck Heads
Badass 3" true dual exhaust.
Old Jun 19, 2001 | 01:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try doing it through the ALDL, as long as you haven't ripped all the wiring out it should still work.
Old Jun 22, 2001 | 11:17 PM
PPonU4Me's Avatar
As stated above, I no longer have the ECM connected. My car is carbureted now, so no computer. But I do want to have manual control through a toggle for the TC. Anyone got any ideas?
'87 Camaro Iroc-Z
'92 350 .040-over
Mild Cam
TBI truck Heads
Old Jun 25, 2001 | 07:52 PM
PPonU4Me's Avatar
Someone, please help with this?????
'87 Camaro Iroc-Z
'92 350 .040-over
Mild Cam
TBI truck Heads
Old Jun 25, 2001 | 10:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As long as you still have an ALDL you can wire it up the same way, whether your ECM is present or not.
Old Jun 27, 2001 | 12:07 AM
Rallyssport's Avatar
I thought you had to have a computer for overdrive trannys? Everytime i see someone install an overdrive tranny they install a computer with it!
Old Jun 27, 2001 | 01:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A computer or vaccuum switch is required for automatic operation of the TCC. If you can live with manual operation you can just use a toggle switch.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
