Crane HI-6 acting crazy
Old Jul 1, 2001 | 07:40 PM
mcconahay37's Avatar
My Crane HI-6 ignition is acting crazy. I sent my old one off to be replaced after it got water in it, and they sent me a brand new onw. Since sending it off, I switched to a non-computer controled vacume advance HEI distributor. I am using an Accel Supercoil that is listed as compatible with the Crane HI-6. I installed the Crane ignition according to the instructions, and as soon as I did that, the car began to run like crap. I adjusted the timing, tried recurving the distributor, and re-checked al my connections. Everything seems to be ok. I noticed that one of the magnetic trigger wires had a nick in it, so I cut the wires back down past it and tried re-connecting it. Still would not run properly. I finally gave up and went back to the stock ignition, and the car runs like a champ now. Any ideas on why this is causing me so much trouble?
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, TH350 tranny with 2500 stall.
SLP 1 3/4" headers
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
